Revolutionary direct modeling powered by Apple Pencil
All the essential tools
Extrude
Loft
Replace face
Revolve
Shell
Sweep
Design with creative power
Direct modeling with Apple Pencil
3D touch activated features put control in your hands instead of a keyboard to make modeling fluid - and enjoyable. Experience a highly responsive modeling UX.
Siemens Parasolid on a native iPad app
Shapr3D runs locally with the same engine as SolidWorks. Create with unparalleled performance, complete offline functionality and CAD compatibility.
Work productively with a smart tool set
Shapr3D tools are engineered to be quick to master and efficient to use. Shortcut complex calculations and self-intersecting surfaces. Each feature has the capacity to snap, guide and auto-complete on a customized grid.
Constraints, Snaps, Items
Lock in mathematical symmetry for your lines, circles and arcs. Customize your snaps to lines, arcs or grids. Organize, and folder parts for easy search.
Boolean commands
Combine separate bodies efficiently using Subtract, Union and Intersect Boolean formulas guaranteed to create watertight, manufacturable solid models.
Transform tools
Move, rotate, mirror and scale models with handily visualized guides. Just choose a pivot point or axis and maneuver your work with precision.
Turn your iPad into a 2D/3D model viewer and editor
Import and export your work to take advantage of the app’s powerful prototyping interface. Shapr3D currently supports X_T, STEP, IGES, STL, DXF, DWG, OBJ, JPG, PNG file formats.
View and edit 2D and 3D models
Import your existing projects and use the app to fit your needs. You can:
  • Develop stronger prototypes efficiently using Shapr3D’s intuitive tools
  • Ideate, present and validate concepts with your clients and team on the spot
  • Work on your designs anywhere
  • Create models using reference images, blueprints or hand drawn sketches
  • Build a flexible creative workflow
Supported formats: X_T, STEP, IGES, STL, DXF, DWG, JPG, PNG
Export manufacture-grade models
Every Shapr3D PRO model is engineered with industry standard quality and structure. You can:
  • Export your work as a solid model or mesh model
  • Send your work directly to your desktop CAD for granular editing
  • Manufacture models without hours of tedious post-processing
Supported formats: X_T, STEP, DWG, DXF, STL, OBJ
Combine Shapr3D with your desktop CAD, CNC machine or 3D printing software
SolidWorks
NX
PTC
Catia
Solid Edge
Fusion
Inventor
Rhino3D
OnShape
SketchUp
SolidWorks
NX
PTC
Catia
Solid Edge
Fusion
Inventor
Rhino3D
SketchUp
OnShape
Try the leading mobile 3D design app for free
Get Shapr3D for iPad
Need a compatible iPad with Pencil?
