Shapr3D Sync Beta
Terms of Use
If you’re reading this, it means you’re selected to try out Shapr3D Sync before its public release. Here are the perks:
  • Safe and secure. Your designs are kept safe on our end and on your devices as well.
  • Backup 24/7. You always have a backup at hand in case something happens to your device(s).
  • Offline first. Your files are available offline so you can work anywhere.
  • Works on Windows PCs and tablets, Macs, and iPads.
  • Your call. Opt in or out of Sync anytime.
How can you start testing Sync Beta?
1.
Turn on Sync in the app and experiment with it.
2.
Share your feedback or ask for help if needed. Here are our channels for getting in touch or learning more about Sync:
A few things to keep in mind
  • Sync keeps your designs safe: Everything is encrypted at rest and in transit and can’t be accessed by a third party. On top of that, your designs can be recovered whenever it’s needed. To learn more about the details, head over to the Sync FAQ page.
  • Sync is account-based. Once turned on, Shapr3D Sync will work on every device you’re logged in, and you won't be able to exclude a certain device from this.
  • Sync is not yet available for Windows. Using Shapr3D on your Windows devices does not have any effect on your Sync experience on iOS and macOS. It’s in the making, though: we plan to release it by the end of summer.
  • Offline storage. Your designs will still be stored locally on your device(s), too.
  • Backup your files. We are doing our best to ensure that the sync process is reliable. However, this is still a testing phase, so make sure that you have a backup version of your critical files.
  • Opt-out anytime! If you want to stop participating in the Beta, just simply disable Sync.
