All articles
Meet Parameter Cards
Announcement
September 28, 2026
Shapr3D
CAD has always made you choose: work fast and loose, or work precise and structured. Shapr3D had both, direct modeling and full parametric history, but they didn't always feel like the same product. The precision was there. It just wasn't as quick to reach, as easy to learn, or as consistent as the rest of Shapr3D. Parameter Cards bring parametric editing fully into the Shapr3D way: quick to access, consistent across every tool, and easy to pick up, whether you're roughing out a concept or fine-tuning the tenth iteration of a finished part.
More precise. Faster.
Every tool in Shapr3D used to have its own logic. Some opened a multi-step flow, some didn't. Some remembered your settings, some made you set them fresh every time. Some parameters were only visible after edit, from the History. Not in the flow, as you model. That meant a learning curve for every new tool, and switching between quick geometry edits and precise parameter work meant switching your whole mindset too.
Parameter Cards fix that at the root: one consistent way to open a tool, see its options, and adjust them, on iPad and desktop alike. Learn it once, and it works everywhere.
Activate a tool and you get the essential parameters as canvas controls automatically. Want more control? Click the tool icon again to open its card and get every parameter, right where you're working. No digging through the history sidebar. It all happens in one motion now.
Confirming and exiting a tool works the same everywhere: tap the empty canvas. That's it.
Every parameter gets saved to history. Jump back into a step from ten edits ago, and the same card, the same controls, are waiting.
Active tool with Parameter Card open
Selection improvements
Tools now have clearer active states, so a new selection adds to what's already active. Fillet an edge and realize you missed one? Just add it while you're still in the tool. The card shows you everything you've selected, so you always know exactly what you're editing.
A fillet is being added to the selection set
Customize placement
Cards open only when you ask. In the top right corner of the card, you can customize when you want the card to open the next time. Never automatically, on Tool Start, and/or on History Edit.
Once one's open, drag it wherever works for you. In the way on iPad? Hide it by dragging it out of the screen, and bring it back by dragging.
Setting Parameter Card visibility preferences
Additional improvements
New interactions and user interface
Persisted settings. Tools remember your last choice. Type sticks on Offset Edge, Scale, Fillet, and Chamfer. Keep Originals sticks on Union, Split Body, and Mirror. Same for the keep/discard picks on Subtract and Intersect.
Tool cycling. Hit a tool's shortcut again while it's active and it cycles the options. E flips Extrude between Single-sided and Symmetric. F flips Fillet Type. Same trick in Chamfer and Offset Edge. (Custom shortcuts carry over.)
Segmented controls.  Certain parameters became icon buttons you tap directly. Live in Extrude, Revolve, Fillet, Chamfer, Offset Edge, and Scale.
Numeric scrubbing. Grab any number field and drag to change the value, or tap the new +/− buttons.
A cleaner sidebar. Drawings moved under Project, top left. Visualization moved into the main menu. More room for your tools.
Note on Parameter Card release: More of you will get it each week as we roll it out, once we've confirmed it works well
